Old 10-17-2013, 06:46 PM   #31 (permalink)
serialk11r
Will you be taking the 2-inches out of the middle to retain the end arc?
One inch off either end. The distance between my taillights is around 38 inches or something, and the S2000 spoilers are 40 inches wide apparently. I think it's better this way because the spoiler ends up higher and that's kind of what this car needs, though it's fractions of an inch either way. The more important reason is because it's easier to make :P
Another idea is to raise the spoiler half an inch with some mini supports and then cut off only 0.5 inches from each end as it'll clear the taillights, but I think that might look odd.
