Old 06-29-2008, 10:27 PM   #46 (permalink)
ttoyoda
ttoyoda's Avatar
There is a program Hull Designer that is used to design boat hulls built out of flat plywood panels. It could also be used to design fairings made of coroplast.
I don't understand the output.
Is each of those segments a flat panel with no bend or twist? Or does the program unbend segments and give the pattern to cut on a flat sheet?
