Old 10-19-2013, 06:39 PM   #41 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Sean.Heihn View Post
Don't those little Kei trucks/vans already get 50+ MPG? Atkinson cycle has horrible low end torque, that's why you only see it in hybrids were the electric motor can supply the low end torque to get moving. So I don't think it'd work well in a cargo vehicle.
Yes & no, my kei van is an EV with some unfortunate issues at the moment. As a gasser in the UK 32mpg US is much more likely, I have not been able to find the 660cc fuel economy from japan (aka an 05 move 5sp, too bad the japanese language is still a barrier) Also low end torque would not be an issue on a 2000lb van that originally came with a 2cycle engine (not much low end on a 2 cycle)
Now what I'd do is buy a 1NZ-FXE (or a small diesel) and make a 'battery pack-less' series hybrid. Have the engine drive a generator to supply electricity for the traction motor/s, with start/stop, a small battery pack to supply power to start the engine/power the traction motor/s while the engine spins up, regenerative braking to charge the battery pack. You'd cut down on weight and cost without the huge battery packs in current hybrids, plus with hub traction motors you'd cut down on complexity, cost, and power transmission loss and the engine, since it only provides power to the generator, can spin at the peak efficiency rpm range. Basically this is how diesel/electric locomotives work.
I would like to convert the Miles zx40 ev to a volt-like vehicle, this would reduce the affects of some unfortunate battery degredation from a collision.
Running it at 42 volts of damaged batteries is no fun.
Ah well, I wonder why the motor is the only cheap part, I would think the whole kabootle would be equally useless and cheap given it only works on a prius, which unless crashed usually never fails.
