Old 10-19-2013, 07:50 PM   #43 (permalink)
serialk11r
Originally Posted by mr220v View Post
The 1nzfe ecu runs the vvti based on rpm. I want to run it based on throttle position. With the setup I have, the vvti actually needs to operate more like displacement on demand than normal vvti. That's the object. Cruise at 750cc's, and move to 1.5L when I need to.
In the case of the spyder, the key would be the 1nz XA bellhousing accepting the spyder differential. I think it probably would. At that point, you would use your existing axles and transmission mounts.
That's not really how VVTi works. The stock ECU is doing about as good a job as it can, it should vary based on rpm and load together. High rpm => retarded intake cam for higher VE, high load + low rpm = advanced intake cam for more power, low load + low rpm = retarded intake cam for lower VE and lower pumping loss. Don't mess with it.
Yea I wouldn't be surprised if some of the 1NZ bellhousings worked, but I still have the exhaust piping to worry about afterwards. In California a custom exhaust isn't going to pass visual inspection for smog, even if the puny looking 1NZ doesn't raise an eyebrow
