Originally Posted by ttoyoda
I don't understand the output.
Is each of those segments a flat panel with no bend or twist? Or does the program unbend segments and give the pattern to cut on a flat sheet?
The images I showed were the part of the program where you can drag the lines around to get the hull shape you want. When it looks good, you can select a button and it will generate the flat panel shapes. It outputs them several ways, visually on the screen and also a dxf CAD file that Autocad can open up.
