Originally Posted by josemapiro
Thank you, my car is a Honda Civic MB3 1999 with the D15Z8 engine, the reference is the Injector 06164-P2A-000, this site says it is an injector Bosch 0-280-150-783.
You can see here in these information sites on the injector.
Okay, this injector appears to flow 209 cc/min (ml/min is equivalent). The reference pressure is 300 kPa, or 43.5 psig. I've read on the intertubes that stock Honda fuel pressure is at 40 psig, or 276 kPa. Assuming 4 cylinders, my MPGuino says that the Microseconds/gallon number is 283300095 (microseconds/liter should be 74839967). What is your number?
The MAP sensor has the reference 37830-PAA-S00. What is a Denso 079800-4250.
You should not need to worry about the MAP sensor. Your car has a traditional fuel pressure regulator that is indexed to manifold vacuum.
