Old 10-20-2013, 04:42 PM   #213 (permalink)
josemapiro
Thank you
I will use these values ​​and see how it works.
Which of these settings, advise me to use in my car:
Code:
#define blankScreenOnMessage true
#define trackIdleEOCdata true
#define useSerialPortDataLogging true
#define useBufferedSerialPort true
#define useCalculatedFuelFactor true
#define useWindowFilter true
#define useClock true
#define useSavedTrips true
#define useScreenEditor true
#define useBarFuelEconVsTime true
#define useBarFuelEconVsSpeed true
#define useSpiffyBigChars true
#define useChryslerMAPCorrection true
#define useCoastDownCalculator true
#define useDebugReadings true
#define forceEEPROMsettingsInit true
#define useEEPROMviewer true
#define useBenchMark true
#define useSerialDebugOutput true
#define useSWEET64trace true
#define useSWEET64multDiv true
If use the MAP does not get better results?
I still need a help is what the letters mean in the LCD menus
Code:
| is ---- t ---- | iL ---- s ---- | iL ---- s ---- |
| ir ---- L ---- | ir ---- L ---- | cL ---- d ---- |
| iL ---- s ---- | cs ---- L ---- | ts ---- L ---- |
| tL ---- d ---- | cd ---- L ---- | td ---- L ---- |
| Cd ---- L ---- | tL ---- L ---- |
| Td ---- L ---- | tT----- d----- |
Thank you
José Rodrigues
