Old 10-20-2013, 06:05 PM   #50 (permalink)
Occasionally6
Originally Posted by vskid3 View Post
One question, how do you figure that the Atkinson valve timing makes it 750cc and 6:1 compression? I've never seen any numbers for the effective compression ratio and I just didn't expect it to be so extreme.
The air/fuel charge is not trapped until the inlet valve closes. When that does occur, the volume of air/fuel trapped is that defined by the remainder of the stroke. Compression likewise does not occur until the inlet valve closes.
