Old 10-21-2013, 09:04 AM   #38 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
You should be able to put a flashlight under the honeycomb and see through it. I vote use the hf exhaust and clean out the converter if you have to. I can send you an o2 that I have laying around that didn't throw a code. It had a bad stumble but it will give you the answer you need without guessing on a brand new sensor.
Burn lean and prosper \\ //
