Big con for a lot of people is speed, if it has 3 wheels and takes up enough space then it needs to be able to keep up with in town traffic, 35mph/55kmh but the USA Federal law limits electric bikes while under electric power to only 25mph and mopeds to 30mph in most states.
The loop hole tho is that you can pedal faster then that, the vehicle speed limit is while not pedaling, so if the throttle was controlled by pedaling then you could go as fast as the posted speed limit for the road and be legal.
You are also limited to a 750 watt motor for it to be a bicycle, this can be governed wattage that can be reset by the user of course, but if you are trying to sell it then it has to be limited.
It also has to be easy to get in and out of, the Twike is not easy, the Elf is easy but is not weather tight because it has no doors!
Advantage of it having a VIN and being licensed as a moped is parking.
