Old 10-21-2013, 07:59 PM   #19 (permalink)
davelobi
davelobi's Avatar
CRX - '91 Honda CRX HF
Last 3: 63.1 mpg (US)
the ugly one - '97 saturn SL just sl,not sl1 or 2
Team Saturn
90 day: 44.15 mpg (US)
Vibe - '07 Pontiac Vibe
Team Pontiac
90 day: 44.24 mpg (US)
Hoopdie - '05 Toyota Corolla CE
90 day: 42.58 mpg (US)
Originally Posted by ProDarwin View Post
I made a IAC blockoff for Saturns quite a while ago. I sold a bunch on sixthsphere.com, and I also gave the drawings to someone else to make more. There are a few floating around on there if you want to pick one up.
The main reason I made it was so the car was way less annoying to shift - RPM drops like it should when you let off the gas and clutch in.
Also, given that you are in Michigan, you could run the car with an MS, or OBD-1 swap the car and tune the OBD1 computer.
ProDarwin, what did the iac cutoff do to your throttle plate closed idle? I also hate when it revs up a little between gears, small but a waste of fuel and the rpm will be lower when next higher gear engages anyway.
Also what did you mean about running my car with an ms?
Get bored very quickly. Vibe, Saturn, and crv all long gone. Been a while but I'm back in the game, gunna see what I can do with this Corolla.
