Originally Posted by Stoked
I didn't see this covered...Some Dodge trucks (and maybe some others) came with 3.08's from the factory. Look for a Dana 61 axle. Similar to a Dana 60, but had an offset pinion to account for the large pinion gear of the 3.08 set. Make sure the gear set in it is good, though, because new ones are almost non-existant. Bearings and seals are all still available as they are the same for a 60.
Correct, a 3.07 gear was standard on the early non-overdrive automatic cummins powered trucks. You want to find a complete axle from an 89 thru mid 91 non intercooled automatic truck.
If you are still trying to figure out how your wiper arms come off, just lift them up like you're cleaning the window and flip the little tab outward from the shaft and let the wiper down onto it to hold it out. You will now be able to jiggle and lift it straight off of the spline, very easy and no tools required.
Travis..
