Old 10-23-2013, 10:23 PM   #62 (permalink)
Occasionally6
Whether or not there's less fuel and air depends on what you look at. For a given power output at the crankshaft, the addition of EGR will mean less fuel and air are required, because the pumping loss is less.
If you hold the amount of air and fuel constant, then the EGR is additional and the power output at the crankshaft increases with the lower loss to pumping work.
Some (more) thermodynamics:
Q = m.Cv.(Tf - Ti)
Q is the heat into the combusted gases (~ N2, CO2, H2O) from the fuel, less losses to the cooling system and oil.
m is the mass of the combusted gases, including EGR if applicable.
Cv is the constant volume specific heat.
Tf is the temperature after combustion
Ti is the temperature prior to combustion.
From that you should be able to see that if you add more 'm' and keep 'Q' constant, (Tf - Ti) must decrease to balance the eqn. More mass, same heat = lower temperature.
It is somewhat complicated by the fact that Ti will be higher with EGR both because the EGR is warm and because the pressure is higher prior to the compression stroke with it. Both act to increase the temperature (and pressure) at the top of the compression stroke.
Hot and cold wrt 'plugs refers to how easily they lose heat (to the cooling system, via the cylinder head). A hotter 'plug is easier to fire, reducing the likelihood of misfire, but may act as a glow plug and prematurely light the air and fuel mixture if too hot; pre-ignition.
At the end of the EGR section, it says the reason EGR increases FE (among other things) is because it increases the mass on the piston, helping to force it down. I wonder if the reason why pgfpro's turbo helped increase mileage was because it helped increase the pressure on the piston, forcing it down against the vacuum.
Gravitational force has negligible effect on the force on the piston; mass of charge, not weight.
The pressure on the non-combustion side, 'outside', of the piston is ~atmospheric pressure, not vacuum. Any low pressure - vacuum if you prefer - is always inside the cylinder. EGR does reduce that vacuum. A lean air:fuel mixture would do the same thing but mess with emissions - high NOx.
Cooled EGR does use a heat exchanger to reduce the temp. of the gases.
EGR will reduce pumping loss. Too much will prevent the air and fuel from burning (think CO2 and steam fire extinguisher).
EGR can be used instead of fuel to cool combustion with supercharging.
The Following 2 Users Say Thank You to Occasionally6 For This Useful Post:
IamIan (10-24-2013), RedDevil (10-24-2013)
