Old 10-24-2013, 12:24 AM   #69 (permalink)
UltArc
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Friday, I am building my Fiberglass lower grille block, boat tail, and maybe an upper grille block. I may have to complete my kill switch, also. Inspector is coming out to review the damage, Honda says over 2k to fix it up, my new IMA is on back order, and they are going to try to have a CR-Z for me.
This past Friday, I visited the Insight graveyard.
I have a Honda S2000; steering wheel, shifter knob, and radio unit (WHICH FIXED MY 6 CD CHANGER!!!). A Honda Civic (Hybrid?) upper grille, a new map net, AC control unit (for selling my AC gear), a lower front fascia (destroyed, but for making a wicked lower grille block), a random flat panel to mutilate, the original Insight rear bag (instead of the net), a passenger headlamp (not really working, might have to use it since this claim is taking forever), a better driver Insight floor mat and more that I will update when I remember.
Original Plan:
1. Rear flat panel
2. Honda Inspection
3. Underbody
4. Partial air dam
5. Side skirts
2nd:
1-1. 2nd times the charm!
1-2. Images will be uploaded in this post.
1-3. Saturday, 0800-1400
1-4. After 3.
1-5. Is in progress, and pretty effective.
Under body is now on pause, I may try to use a local tune shops since drag season is almost over. Inspection was fantastic, the noise was my rear right skirt having a broken tab and clanking in sharp turns. No air dam. Side skirts are off the table for now.
I did have a stroke of genius, I think.
In all my reading of front wheel skirts, I noticed a flaw. Increasing frontal area. But I noticed something else about all the designs I've seen that seems to correlate.
http://ecomodder.com/forum/showthrea...kirts-398.html
http://ecomodder.com/forum/showthrea...-0-a-5462.html <Metro & AeroCivic
They all mount from the top. Why not mount flush and at the front? I may even have time to do my IMA on/off switch. A lot to do, a lot on my mind.
Game plan:
Get the mold started for the upper grille block, wax, wax paper, tape to line it. Fiberglass then resin in, medium thickness layer. Then, I take it inside to dry while I work on the boat tail. Wooden frame at the end, wooden frame at the base. Then, wood to attach the two squares. The plan is 11 pieces of thinner wood, and secured to the bike rack. When the frame is built, poly carbonate underneath, above, and on the sides. The rear will hold the tag, but be open so I can still see through the slick glass at the rear. As I get set with the FG drying, I will fill with great foam SLOWLY, in small amounts. The upper grille block will be assembled out of the Civic grille I have, but is pretty low on the list. I'd rather get my KS and IMA O/O switch done, first.
The front wheel skirts are pretty far out on my timeline, but the potential ease of fiberglass has inspired me. All in all, big plans.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
