Any modification will be counter by the ECM and the air-fuel sensor on the exaust manifold
If you lean it out, the ECU will bring the Air/fuel ratio up.
If you want to lean your engine, either you reflash your ECM/ECU or you mess with the Air/Fuel sensor.
It's my suggestion.
