Old 10-25-2013, 08:14 AM   #10 (permalink)
Occasionally6
Are you sure the only thing it does is indicate idle? With the MAF disconnected there has to be some other way of determining the fueling, either MAP and rpm or TPS and rpm. With a MAF, it's unlikely to be the MAP.
There are systems that do have a TP switch (or switches) but they won't run without the MAF.
