Old 10-26-2013, 03:18 AM   #226 (permalink)
josemapiro
Originally Posted by t vago View Post
Yah, it's normal. Anything, that wakes up the MPGuino, will reset the current trip data. It could be any single button press (or pressing any combination of buttons), or it could be a VSS pulse, or it could be a valid injector pulse.
I am wondering if this particular behavior should be changed - button presses, by themselves, would not necessarily reset the current trip if the MPGuino were to be woken up, but reading a VSS pulse or a valid injector pulse would still do so.
I think the best would be to reset by pressing the button for 1 second, because there is always the possibility to query all data from the last trip.
If the data is restarted due to the injector pulses, this means that we will make another trip, which is correct, the rest I believe it should only be done if we wish so.
Or create a possibility to choose in the setup menu.
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (10-27-2013)
