Old 10-26-2013, 03:51 PM   #15 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by euromodder View Post
That's when you run into the basic design flaw of most current cars : the radiator is in the engine compartment. So in order to cool it, you have to let cold air into the engine compartment.
Or design a radiator duct that doesn't end up in the engine compartment.
Ah, but the heat which is taken off of the radiator is then blown back over the engine block. Maybe good for warmup times when your t-stat is stuck open, but not very efficient as a cooling system.
Putting something between the rad and engine that would shield the latter from air and heat wouldn't be a bad idea. Except that most engines rely on that airflow to cool alternator and/or oil.
