Originally Posted by elhigh
You're a funny guy. I've got a '45 Farmall whose wheels mount with studs, and the offside wheel has a 165lb counterweight built into it. What I wouldn't give for stud mounting at that point... Thank God those tires can take a lot of abuse.
Just my two bits.
My '51 Allis WD uses bolts, and a bunch of 'em. Although I don't have your counterweight, I did discover that my tires (only one now) are fluid-filled. Taking them off to patch a hole is one really messy job! I look forward to having the restoration done and brand new DRY tires mounted (less so the work of mounting them
Vol
