Originally Posted by mechman600
My understanding is that staying in a higher RPM range for a given load means that the voltage at the motor will be higher and the current lower (since Watts = Volts*Amps), and since higher current (amp) levels = generated heat/inefficiency, this is better.
Hmmm...
For a given motor resistance, the power lost in the windings is I*I*R. So less current should be WAY LESS losses. That makes sense.
Reducing the motor current by increasing the applied voltage will drop the winding losses. Check.
What about the brush-to-commutator interface? Does higher voltage increase the losses there, even without arcing? I don't see why it should ...
So is there a down side to running the motor at (relatively) higher rpm?
If you confirm the sweet spot, it would interesting to find out WHY it's a sweet spot.
