Old 10-28-2013, 01:53 AM   #44 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Never mind you got it. They way you have it is correct. See on the back of the sensor connector where that flat spot is? I believe the resistor is in there. There is a brand new Honda sensor on eBay right now with only 5 wires.
I hate to sound like a broken record but check the wiring again. And make sure all 7 of those wires are going where they need to. I remember when I did my swap I ran into that and got confused and I just wired it the way the diagram said and I had no problems. Later is when I found out about the resistor being in the sensor connector.
Burn lean and prosper \\ //
The Following User Says Thank You to slownugly For This Useful Post:
nitebluesky (10-28-2013)
