Old 10-28-2013, 05:26 PM   #21 (permalink)
RedDevil
90 day: 57.12 mpg (US)
They sure are. They also claim 36 km/l - you can do the math.
The difference really is in the gearbox.
Toyota's 'infinite gear' planetary HSD system can only cover 3 ratios without a loss; the other ratios involve using a pair of electric motors as a generator and motor to simulate a gear in between. It can use the electric motors alone (without the ICE) in EV mode; but it is a bit of a compromise in terms of gearing for RPM.
Likewise, Honda's current CVT gearbox and IMA system have their problems and inefficiencies - the ICE always runs in EV mode, albeit in DFCO with open valves; the CVT has relatively high friction, and the electric motor has to operate at the same RPM as the engine - it replaces the flywheel...
None of these problems exist with the new system.
The Fit now uses lithium-ion batteries to boot, that will enhance the EV efficiency compared to the old NiMH batteries.
That all should explain why the Fit does better at the JDM/Euro cycle tests, despite being bigger.
Progress...
