Old 10-29-2013, 08:28 PM   #29 (permalink)
funkhoss
The Little Car - '00 Chevrolet Metro
90 day: 91.08 mpg (US)
The Big Car - '94 Chevrolet Caprice Wagon
90 day: 44.9 mpg (US)
Originally Posted by 101Volts View Post
How's the tire pressure? You might benefit from seafoaming the car...
Tire pressure is at 40 PSI. I've Seafoamed the gas tank and intake; I plan to Seafoam the crankcase too before I change the oil.
If you're going to keep at it, You could check out the Garage section of this website and add your wagon to the fleet.
I'll see if I can do that in the next few weeks.
Maybe the Vortec 4300 V6 would be more suitable than the 4.3L V8.
Both engines have basically the same hp/tq figures, but the V6 would require different wiring, exhaust, possibly mounts, etc. The V8 would literally be "plug and play."
Originally Posted by arcosine View Post
A 2.2L I4 vortec engine and 5 speed manual transmission from an S-10 would yield the best mileage for an engine swap, probably would gain 6 mpg.
I do think that would be too underpowered, even when driving without a load. And I'd certainly have to change the final drive ratio. A Vortec 3.5L or 3.7L five cylinder with manual might be a usable and efficient swap, but for the amount of work that it would require, I'd rather just go with a diesel.
-Sam
