Old 10-30-2013, 08:43 AM   #3 (permalink)
kach22i
Originally Posted by paintme205 View Post
Looks like the kammback is a little too steep.
I think that the conventional wisdom in the forum for this situation is that it need not fit the template, but should not exceed 22 degrees.
T-Vago, I believe that the inside body curve is as important as anything else in that diagram. The "G-G" location on the car far above is quite an abrupt angle.
Paintme205, can you do a tuft test?
