Old 06-30-2008, 01:48 PM   #3 (permalink)
groar
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Originally Posted by saunders1313 View Post
I usually ride my motorcycle so I haven't noticed too much until last week. But if you don't shift into neutral either coming to a stop or going down an incline (even fairly low grade) you're engine braking.
In engine brake my cars are stopping injectors so I'm traveling for freeee (and these additional e are free toooo;-) : 0l/100km = infinite mpg :-)
I started shifting into neutral and found that 95% of the time going down an incline I was either staying at the same speed (low grade inclines) or I was actually speeding up, while in neutral. Suggest to anyone new that you start doing this, even coming up to stops you can coast quite far in neutral.
While coasting engine idling my cars are consuming gasoline : 1l/h (0.26g/h).
Usually I'm using DFCO (Decelerating Fuel Cut Off) aka Engine Brake. I'm using Coasting Engine Idling if I know I need more speed at the bottom of the current hill to go up the next hill.
I never use EOC (Engine Off Coasting) as I feel this is too dangerous for me.
Tips #43 is talking about the different ways to "brake". For each one there is at least one situation where it's best.
Anybody have to thing about his feeling for each technique 1st and apply 2nd.
In any way, a technique you don't feel good with, will never be a good technique for you to apply.
Remember the (2nd) credo of this forum : safety 1st, courtesy 2nd and saving gas 3rd.
Life long, safe and prosper ;-)
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
