Old 10-31-2013, 06:42 AM   #136 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Control freaks makes a front subframe kit for this car. It's a tubular type subframe that also converts to rack and pinion and updated coil over suspension. And I believe disc brakes in the front as well. If its not in that kit scarebird makes the conversions. That's probably about the farthest I'd go. Maybe I could glue a whoopie cushion onto the steering wheel as an airbag.
The thing that scares me is the steering column. Like my old tech teacher said if you get into an accident with an older car the steering column turns into a spear.
Burn lean and prosper \\ //
