It didn't last long before something else broke... rear ring gear on the AMC20 started spitting teeth because of a loose bolt.
Its almost fixed, installing front and rear Dana 44's with 4.56 gears 5th gear at 75 should turn 2500 rpm on the future planned 35" tires. Previously with the 3.54 gears on 31" tires I couldn't hardly use 5th gear.
