Old 11-02-2013, 08:46 AM   #241 (permalink)
Ardent
I'm cringing a little at the blinking I/C/T special chars.
When briefly glancing at a display (which should be the case while driving!) it will be easy to miss the "illuminated" indicator.
Case in point: my solder station blinks the power LED when hot, and so I need to look extra long to verify it has been turned OFF as a quick scan can fall between blinks.
The Following User Says Thank You to Ardent For This Useful Post:
t vago (11-02-2013)
