Old 11-02-2013, 03:29 PM   #2 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by chefdave View Post
Hi
after taking advice from other forums dealing with toyota hilux's. i have started a passive oil change with stunning reasults. i went from dexron 2 (no longer avaiable) to dexron 6. Not all auto boxes can use dextron 6. Gained 1-1.5 mpg overdrive comes in earlier.
Nice work!!! I'm also running a non-stock trans fluid in my modified auto transmission with a W4A33 5-Friction Front Clutch Pack for OEM Basket
IPT End Clutch kit, and HyGARD transmission fluid to tightening up stock converter.
Pressure Gradient Force
The Positive Side of the Number Line
