Old 11-02-2013, 07:01 PM   #3 (permalink)
nathan01xl
nathan01xl's Avatar
The Long Ranger - '01 Ford Ranger XL
Pickups
90 day: 28.68 mpg (US)
EcoSI - '08 Honda Civic SI
90 day: 28.83 mpg (US)
Sure there are some limitations with a relatively small engine in a truck, but eventually you might overcome this issue messing with the camshaft, ignition timing, exhaust pipe... Well, the list goes on...
And some weight savings are also a good measure.
Looking into it deeper, many Ranger guys are running 31s on 3.73s with good results on the same 2.3l DOHC(154 ft-lbs), especially on the highway. Though most prefer to regear to 4.10, because they are more offroad or towing oriented. The difference between stock tires(225/70/15) and 31s is about 12%, so my thinking may be too conservative! With my improved aero and driving style I could probably get away with a 10% net gearing change after tires and rear end swap with no issues.
Unfortunately there is not much available for power/efficiency mods on this engine without spending big money...
