Thanks for the insight guys.
So if I raise it up a couple degrees, that would make the roof to kammback transition smoother?
I Have some extra material for the sides tucked under the main sheet of sheetmetal. I am going to try and pull it out a little to make more of a radius from side to top.
On the A-B-A testing. What is a good way to do it since I don't have any instrumentation or a scangauge? Only thing I can think of is drive like 40 miles one way and then repeat over and over. Even then we are talking 1 gallon fills. Any ideas how you would do it?
