Old 11-03-2013, 08:38 AM   #9 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Originally Posted by chefdave View Post
Hi red yaris
what did you use for the underbelly to streamline it. also how did you fix it to the chassis
I used 1.5mm [0.06"] thick aluminium for the belly pan, which I afixed to the main frame rails with self drilling screw covered with silicon sealent to prevent rust. What you need to do is take a look around under the vehicle and see where it would be conveniant to attach. I would take some pictures of what I have done, but there is over 20cm of snow on the ground.
On one section at the front I instaled a peace of pressure treated wood onto which I could scew the aluminium panels.
I had a sheet metal shop make some angle peaces for the section behind the rear wheels.
What it all comes down to is each vehicle is different and needs its own solution...
