Old 11-04-2013, 06:34 PM   #12 (permalink)
aerohead
sketch
Originally Posted by chefdave View Post
Hi
could you draw a rough sketch of door fairings you where talking about. roof next spring will have air con unit and front sky light removed. mirrors have been thought about. thinking of mount ing on bottom of overcab unit and some sort of drag reduction fitted. this hopefully will remove the scaffolding holding mirrors at present. Mirrors will go to 10x6 instead of 4 units of 6x6.
Thanks
dave
Here is an image of what NASA did to a Ford Econoline van.The large radius nose sections of the van would be placed in front of the squared-off leading edges of the RV.
They could be 1/4-section members,hinged at the outer edge,and swung into place and latched after the doors were closed,or attached to,and move with the doors (which would be safer if you had to egress in an emergency),with the upper section of Plex or Lexan so you could see through it,just as NASA has done.
Here's the photo
