Old 11-05-2013, 12:27 PM   #24 (permalink)
Daox
More cool stuff going on. Check it out.
1) Heat pumps for dummies (beginners guide)
Do you want to know what a heat pump is and how and why its so efficient? Check out our new thread that attempts to demystify these devices. If you know a lot about them we need your help too to make this thread a great resource.
Heat Pumps for dummies (beginners guide) - EcoRenovator
2) LED lights - What're you using?
Have you used LED lights? Would you like to know what works and what doesn't? Check this out to see what is working and what isn't for people.
Anyone using/used LEDs? - EcoRenovator
3) Are the sub $300, 400w wind generator from china/ebay worth it?
ATLleaf asks if cheap chinese wind generators are worth it.
Are the sub $300, 400w wind generator from china/ebay worth it? - EcoRenovator
4) Low power modem and router
How much power does your modem and router suck up? You know those things that are plugged in 24/7... Its worth a look.
looking for a low power modem and router - EcoRenovator
5) Free air source heat pump project
Hikerjohnson finds a free air source heat pump on the side of the road and is starting to fix it up for his own use.
Air Source Heat Pump Project! - EcoRenovator
The Following User Says Thank You to Daox For This Useful Post:
mikeyjd (05-21-2014)
