Old 11-05-2013, 03:25 PM   #251 (permalink)
josemapiro
The result of my first 200km with MPGuino were fine, not sensed any fault, showing the great work the t vago. Still have not adapted well to the menus, but with time it will improve, below I will make some suggestions that might help.
Originally Posted by t vago View Post
That might could work. Or, maybe have these blinking special characters appear for 1.5 seconds, then disappear for 0.5 seconds.
Yes 1.5 or 2 seconds, it is a matter of try and see what works best.
This is why I made it a requirement that any code I added would still have to run on legacy hardware, even if the code will also support better or more advanced hardware. This is why I am not currently thinking of supporting anything other than a 16x2 LCD display.
Glad you stayed true and did not follow my deviations because we must not forget the others.
The suggestion I have to make has to do with the position of the values ​​in the menus. Sometimes changing menu have the same values ​​but in different positions, the idea was to try to maintain the same positions in the various menus for easier identification.
What do you think?
Code:
"Instrument"
| instant FE        - instant speed |
| instant fuel rate - tachometer    |
"Custom"
| instant fuel rate - current FE    |
"Instant/Current"
| current distance - current FE    |
"Instant/Tank"
| tank distance - tank FE       |
"Current"
| current fuel used  -  current speed |
"Tank"
| tank fuel used - tank speed |
"EOC/Idle"
| current EOC distance - current fuel used at idle |
| tank EOC distance    - tank fuel used at idle    |
"Remaining"
| tank fuel used     - tank fuel remaining    |
| tank time to empty - tank distance to empty |
Thank you
José Rodrigues
