I'm looking for beta testers who are willing to build, install it, and then write a comprehensive report on the experience for the forum.
Free $30 current hack pcb for beta testers who come on board this month.
Kit's Also Available.
OK to make it easier for people I now offer the option of the IMA boost device as a complete kit (minus the cable it's expensive to post from the UK). Cost will be $30 extra on the pcb only price. That makes it $85 all in.
IMA Boost Kit will comprise.
1 x Pcb
2 x Micro pcb screws for case
1 x Non flanged Hammond black plastic case with screws
1 x 3mm Bi Colour Led
1 x Programmed 12F683 pic
1 x 8 Pin IC socket
2 x 330R 1/8w resistors
2 x 4k7 1/8w resistors
1 x 100uf cap
1 x 0.1uf cap
7 pins sil pins 0.1" and jumper
2 x 10k pots (Non knob type)
1 x 5 way screw terminal
1 x push button
You need to supply the cable, 4 or 5 core (2M) an old black usb 4 core cable is a good option for this.
You need a pic programmer to keep upto date with software development as per OBDIIC&C.
Mike D at
www.99mpg.com has programming kits on offer at the moment IIRC
You need a fine 1mm tip soldering iron, you won't be able to do it with grandad's old farm tools.
I might offer a built option later, price ~$170.
