As far as VE goes with this motor, I suspect that when you "reclaim" your full 1.5L, you also tend to overlap the exhaust cam more as well. This would lend itself well to a better VE at higher rpms.
You could possibly degree the intake cam to close earlier and overlap the exhaust cam even more on the high setting.
