Old 11-07-2013, 01:23 PM   #26 (permalink)
Daox
Here is some more stuff. Check it out!
*) Win free stuff in our fall giveaway by posting in the forum
We're giving away some great prizes, from a TED 5000-G whole house
electricity meter to a Kill-a-Watt, to low flow showerheads, to a Black &
Decker thermal leak detector, and more. To qualify to win, all you
have to do is participate in the forum between now and the end of
November. Every post you make counts as an entry. More details:
2013 EcoRenovator Fall Giveaway! (Just post in the forum to qualify.) - EcoRenovator
1) What kind of PEX tubing for hydronic heat?
Daox is getting ready to put in a hydronic floor in his office, so he inquires about what PEX tubing to use for it.
What kind of PEX tubing for hydronic heat? - EcoRenovator
2) DIY solar dehumidifier
NiHaoMike contemplates a DIY solar dehumidifier using calcium chloride as a desiccant.
DIY solar dehumidifier - EcoRenovator
3) Building an attic door insulation enclosure
RobbMeeX contemplates buying or building an attic door enclosure.
Building an attic door insulation enclosure. Thoughts/Help needed... - EcoRenovator
4) Solar space heating for shop
Randen is building solar hot water panels into the outer wall of his shop to heat it.
Solar space heating for shop - EcoRenovator
5) Another hot water tank heat pump
In addition to the solar hot water project, Randen also salvaged a hot water tank and window A/C unit that he is hacking into a hot water heater.
Another hot water tank heat pump - EcoRenovator
