Old 11-08-2013, 08:00 PM   #74 (permalink)
cRiPpLe_rOoStEr
Originally Posted by stillsearching View Post
I guess i'm just wondering if that was an early Atkinson cycle, or the Prius-engine is just the modern take on that idea which seemed to be almost abandoned after it's brief stint in the aftermarket in the early 1980's.
The original Atkinson cycle had an articulated crankshaft to provide a power stroke longer than the compression stroke, while the currently-called Atkinson cycle doesn't. It's basically closer to the Miller cycle, altough without the supercharger which is used in the Miller cycle to overcome the output reduction.
