Thread: Need help...
Old 11-08-2013, 09:01 PM   #2 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
"InjTrg" is used by MPGuino to determine whether your fuel injector has a switched ground (most cars) or a switched power lead (Audis, maybe others). Normally, "InjTrg" should have a value of 0. If it's 1, you will likely see strange behavior (like fuel usage rate being larger at idle than when you're driving down the road).
Also, "VSS Delay ms" might should be 1 instead of 0. IIRC, Geo Metros used a mechanical VSS pulse generator, that required debouncing.
The Following User Says Thank You to t vago For This Useful Post:
redneck (11-08-2013)
