Yep, plans are to repaint the whole thing, at least touch up the bottom and repaint the visible areas and bedliner/undercoat the bottom of the body.
I understand the bed sides are 2 part, and where to 2 parts go together isn't painted, just joint sealer. I'm planning to take it apart, sand / repaint and reseal the joint up and reattach it. Probably rivets or small bolts since I think it is spot welded.
