Originally Posted by serialk11r
Those are diesel engines, not the same thing. A spark ignition engine running 1.1 equivalence ratio, max possible compression with minimum possible pumping and volumetric efficiency, and a turbo to recover the very slight amount of blowdown would be more efficient than a diesel at peak load yea. Efficiency depends on application and operating conditions.
More than anything, it depends on how you drive, and while diesels do operate differently, they are still pumps. The same vehicle with a turbo motor will almost always come with a smaller engine that makes more power and if you stay off the gas, it will do better on gas... those are the facts.
