Thread: Low cost BMS
Old 11-10-2013, 11:29 PM   #99 (permalink)
Astro
Dreamer
@harlequin2 have you considered listing the cell top modules and master modules on eBay?
I would be interested in either a PCB only or if available a kit where you get the PCB and components and then build it yourself. Even selling pre-programmed pic chips would probably help a lot of the less technical EVers that would like to use you system.
This looks like a very nice BMS, very elegant. I like that it is simple enough to be easily understood yet complex enough to do the task. Well done.
Last edited by Astro; 11-13-2013 at 03:49 AM.. Reason: Add pre-programmed PIC suggestion and fix typo's.
