I thought you were running a vx harness. Anyways the biggest tell tale would be to look for that 7 wire o2 sensor plug. Which color wire had an open? If you do hardwire it remember not to cut the o2 sensor plug because the resistor is in there. It must be wIred after the plug
Burn lean and prosper \\ //
