Atkins cycle refers to a motor with a power stroke longer than it's intake stroke. Originally this was accomplished with weird crankshaft/engine designs, but can also be accomplished with offset cams and cam timing, which is what this motor does.
Offset cams are often used in race engines (or by cheap 4age modders who only want to buy an intake cam). But again, the object there is to increase intake and exhaust cam overlap (better efficiency at higher rpms), not to delay closing of the intake valve to actually waste a significant portion of the compression stroke. That would be counterproductive in a race engine.
