I started to experment with EOC this week... My car has electric steering which make live much easier. I know alot of people are concerned with reserve vacuum for the brakes but I have found that I have enough for at least two applications and that is if I lift completely off the brakes each time.
I al looking for a means of cutting off the fuel to the engine without turning the key... so far I am aware that the fuel management system is supplied but a fuse that is separate from the ECU.
I am thinking about installing two momentary switches. one normally closed to that will interrupt the power to the FMS and a normally open that will supply current to the starting circuit if required.
