Old 11-15-2013, 08:51 AM   #12 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
So you are running the cylinder without air going in or out? That would be like adding a shock absorber to the crank. And you will lose more than 25% of your power because the other 3 cylinders will be pushing this unused cylinder around. You'd be better off removing the piston completely rather than leaving it as is. And the oil burning issue will not go away. There is something leaking oil, and it was going into a cylinder and being burned off. If it is leaking into the burnt cylinder, that could be a major problem...
Have you ever heard an old Harley engine and seen it shake? They are designed as a 3 cylinder engine with one cylinder removed. There is indeed a reason old Harleys leave oil everywhere.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
