Old 11-15-2013, 01:37 PM   #5 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Weber95 View Post
Thanks you, and I already got the tires pumped to 37psi/40 I don't want to go too high, I heard that over inflating wears the tires unevenly.
Check the maximum pressure - should be on the sidewall of the tire.
You should be OK up to that pressure - and usually, even when well above.
I'm running 43.5 psi in a 2100lbs car without issues about uneven wear.
