Old 11-15-2013, 07:21 PM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Weber95 View Post
Euromodder: Does pumping the tires up 6-7 psi more give that big of benefits?
Yes.
36 psi is low.
40 is just about getting there.
44 gets better mpg still.
That's on my 2100 lbs car , your truck would be a fair bit heavier.
The ride will be firmer, but it shouldn't get bouncy
(which you may run into when running the truck unloaded on what I expect to be a fairly simple rear suspension - stiff axle and blades , is it ?).
If it gets bouncy, back off the pressure a bit.
