Old 11-16-2013, 03:25 PM   #5 (permalink)
fjasper
Bookworm
Sylvio 2 - '04 Audi allroad quattro Biturbo 6-spd
90 day: 25.09 mpg (US)
Atlas - '04 Audi allroad 2.7T 6MT
Short answer: No. Not worth it, money-wise.
Longer answer, all other things being equal (which they almost never are):
Lighter wheel = less energy spent accelerating and decelerating. Lighter is better, efficiency-wise.
Wider tire = less rolling resistance (sounds weird, but it's true) but more aerodynamic drag. Wider is better at "low speeds."
Narrower tire = more rolling resistance (same disclaimer), less aerodynamic drag. Narrower is better at "high speeds."
The aerodynamic effect of a wider wheel seems like it might be exacerbated slightly by the offset. They might expose more tire to the airflow around the car.
Personally, I'd be a little hesitant to run 11 pound, 15x7 wheels on the street. If they're cheap (cast), they're probably pretty tender, and could be damaged by potholes that wouldn't affect heavier wheels. If they're expensive (forged, etc.), they're probably too pretty to risk curb rash, theft, etc. Like I said, that's just me.
Probably you should just send those troublesome wheels to me so I can deal with them.
